i suck
Old Jan 12, 2009 | 10:44 PM
BrunoBoy650's Avatar
Default RE: i suck
ORIGINAL: dsm1990gsx
ORIGINAL: estraw
Your 60 ft times suck and in run 1 there is no way its 1.0. How did you launch?
read run 1 closer n00b
LOL thanks I changed it.
idk, I revved up held it at 5, clutch at grab point, E-brake til last yellow, and let go of ebrake..
Default RE: i suck
ORIGINAL: EMonz57
2.5 60fts? What the hell were you doing? You def should be in the 1.7 range at least. That alone will run you closer into the 14s
my tires are also almost bald.....=/, I know 2.5 is worse than FWD
Old Jan 13, 2009 | 05:11 AM
Default RE: i suck
ORIGINAL: BrunoBoy650
ORIGINAL: estraw
dont use the ebrake that is prob not helping you any bit with your launch. Even with tires you should do alot better than 2.5s Just hold the RPMs up at like 5-6k and come off the clutch at a steady but quick pace. Or you can side step the clutch and stomp the gas lol but that is extra abuse
Old Jan 13, 2009 | 07:27 AM
Default RE: i suck
Yea you need to slip that clutch alittle more and get rid of the damn ebrake. There is no need for that. Even on my RWD i was hitting 2.1. You should be below 2.0 at least.
And what is with the very low traps...you should be hitting around 95mph. Is something wrong with your car? Are you having problems shifting too?
Old Jan 13, 2009 | 11:38 AM
dsm1990gsx's Avatar
Default RE: i suck
After you launched did it bog down?
Old Jan 13, 2009 | 11:40 AM
Default RE: i suck
ORIGINAL: TheEngineer
my car stops after 6200 rpms...im having issues with my spark blowing out under boost so my car would slow down and then i would have to react to it by shifting(takes atleast half a sec), n i am sure i have a couple BL's. mmm My shifting arm was pretty cramped up as well and I was slow.
Old Jan 17, 2009 | 01:54 AM
ProjectDrknss's Avatar
Default RE: i suck
wow. my a/t gsx runs 1/4 mile in 17.01 sec. just like the hondas...
Old Jan 17, 2009 | 11:26 AM
estraw's Avatar
Default RE: i suck
ORIGINAL: ProjectDrknss
1g? i believe that, the 1g auto's had tiny turbo's on them
Old Jan 28, 2009 | 12:39 AM
Default RE: i suck
No, it's not a 1g. It's the 2g you see in my picture.
Old Jan 28, 2009 | 09:26 AM
Default RE: i suck
So the whole time you are sitting at the light you are roasting the clutch?
