i suck
ORIGINAL: dsm1990gsx
LOL thanks I changed it.
ORIGINAL: estraw
read run 1 closer n00b
Your 60 ft times suck and in run 1 there is no way its 1.0. How did you launch?
ORIGINAL: EMonz57
2.5 60fts? What the hell were you doing? You def should be in the 1.7 range at least. That alone will run you closer into the 14s
ORIGINAL: BrunoBoy650
idk, I revved up held it at 5, clutch at grab point, E-brake til last yellow, and let go of ebrake..
ORIGINAL: estraw
Yea you need to slip that clutch alittle more and get rid of the damn ebrake. There is no need for that. Even on my RWD i was hitting 2.1. You should be below 2.0 at least.
And what is with the very low traps...you should be hitting around 95mph. Is something wrong with your car? Are you having problems shifting too?
ORIGINAL: TheEngineer
