Need some help with an engine (420A?)
Old May 24, 2006 | 08:19 PM
Sanguinius's Avatar
Default Need some help with an engine (420A?)
All right a friend of mine drives a '98 Dodge Neon with the 2.0 engine. I'm fairly certain that it's the 420A. I'm not for sure but I need to know what engine she has as well as if it's an interference engine (She just snapped the timing belt). I'm going to be working on it tommorrow at work so someone let me know please.
Old May 24, 2006 | 11:43 PM
Default RE: Need some help with an engine (420A?)
yup its a 420a, not sure of the other thing though
Old May 25, 2006 | 10:08 AM
slow420a's Avatar
420a was only equiped in the 97-99 neon r/t, all base modles have the a855 motor, same thing as the 420a but its a sohc.
Old May 25, 2006 | 10:16 AM
oh yea your right...i missed that when i researched. Good catch
Old May 25, 2006 | 07:20 PM
and all are interferrence motors correct? I would assume so
Old May 25, 2006 | 08:23 PM
Sanguinius's Avatar
I REALLY hope it's not an interference motor... Anyone know? And if it is I need to know a way to test the valves to see if they're bent.
Old May 25, 2006 | 11:03 PM
yes it is an interference engine. Both the 420a and the a588 were.
Old May 25, 2006 | 11:32 PM
Sanguinius's Avatar
Well then a way to test the valves without ripping the head off? Anyone?
Old May 25, 2006 | 11:34 PM
well if she snapped it while driving theres probably a good chance that some of them are bent. I dont think there is any way to know unless you take off the valve cover and look at them
93eclipsegsx's Avatar
do a compression check. and if one reads 0 then there it is. well thats what we did on my car.
