Some tips and guide on how to properly maintain car battery
Old Dec 28, 2020 | 08:44 PM
fightingraven's Avatar
Thumbs up Some tips and guide on how to properly maintain car battery
No one wants to be stuck in the middle of the road due to a dead battery. That is the main reason why you need to keep your car battery in place properly.
If you don’t know much about car battery maintenance, you can refer to some tips below. Hope you find this helpful
Regularly check and clean car battery terminals
Corrosion and rust on battery terminals negatively affect the life cycle and performance of car batteries.
When cleaning the battery terminals, you can use water with baking soda with a mixture of 1:1. Remember to disconnect the negative side first. You also need to make sure that the two wires do not touch any other vehicle's metal components.
For better protection, the terminal spray can be used to coat the battery terminals. It will further prevent the build-up of corrosion.
Regularly check the battery and tighten the hold-down
Car batteries have bars that keep them stable and help avoid vibration damage. You should also pay attention to its hold-down when checking the car battery. Try shaking your battery and check if it's moving, which means the hold-down is loose.
Check the level of battery fluid and add if necessary
Use a flashlight to check the level of fluid in each cell. Your battery has enough fluid to cover the battery plates. If not, it means that it does not have sufficient fluid and needs to be refilled.
I also recommend using only distilled water instead of tap water. Tap water contains dissolved minerals that will affect the performance of the battery.
Driving regularly will help maintain the charge in the battery
The battery is recharged when the car is running. That's why you should not leave your vehicle idle for an extended time.
yadriver
Sep 10, 2013 09:26 PM
HazardousOmega
Mar 27, 2013 04:40 PM
dsm1990gsx
Sep 21, 2008 07:41 PM
shreff99
Nov 22, 2006 02:12 PM
motaz
May 18, 2004 09:34 AM
