I have got triton MN 2015 when i switch air condition makes noise as V-Belt is loose looking to tighten the belt and I am following the instruction in the attached service manual (Pajero same as Triton)
Adjust the A/C compressor drive belt tension by the following procedure.
1.Loosen the locking nut of the tensioner pulley.
2.Use the adjusting bolt to adjust the drive belt tension or drive belt deflection to the standard values.
Socket is 22mm but very hard to fit it on the locking nut middle pulley in the attached photos because of the fan blades
I marked tensioner pulley with white line
Is there a specific tool that helps to loose it the locking nut ?
