Mitsubishi Triton 2015 tool reuired to loosing locking nut for tensioner pully
Old Nov 9, 2025 | 12:40 AM
zillah's Avatar
Default Mitsubishi Triton 2015 tool required to loosening locking nut for a tensioner pulley
https://mitsubishiforum.com/forum/mi...nsioner-38020/
Dear All
I have got triton MN 2015 when i switch air condition makes noise as V-Belt is loose looking to tighten the belt and I am following the instruction in the attached service manual (Pajero same as Triton)
[W/M]PAJERO SPORT/NATIVA/MONTERO SPORT/CHALLENGER(KG#,KH#)
Adjust the A/C compressor drive belt tension by the following procedure.
1.Loosen the locking nut of the tensioner pulley.
2.Use the adjusting bolt to adjust the drive belt tension or drive belt deflection to the standard values.
Socket is 22mm but very hard to fit it on the locking nut middle pulley in the attached photos because of the fan blades
I marked tensioner pulley with white line
Is there a specific tool that helps to loose it the locking nut ?
Thx
Careful
Sep 6, 2017 09:22 PM
Paray
Jan 22, 2007 09:54 AM
