00 3 liter Eclipse, running problem
Old Jun 13, 2013 | 01:39 PM
skagitmobilerepair's Avatar
Default 00 3 liter Eclipse, running problem
We have this issue. The car surges and runs horribly. Extreme lean condition. O2 sensors function, checked with adding propane. Good fuel pressure. Disconnect Mass Airflow and it runs great. New MAF runs bad again. On VW, this is how you diag the MAF. Anyone have this problem? Obviously not an injector or ignition problem. I'm starting to thing the ECM is bad.
Old Jun 13, 2013 | 03:54 PM
Check your maf wiring harness.
Also check your throttle body. Make sure it opens and closes freely, then clean it with some carb cleaner.
Old Jun 14, 2013 | 01:00 AM
We've done that too. Thank you for the advice. Never too experienced to take some good direction. The funny thing is that there's no codes.
ChryslerMan
Feb 10, 2012 12:22 AM
mark_hou
Sep 10, 2010 10:15 PM
l-e-o-n-a-r-d
1st Generation
Jul 2, 2009 06:04 PM
zncus
Nov 23, 2008 11:20 AM
zncus
Nov 10, 2008 06:24 PM
