03 Montero Limited cranks but won't start
Old Apr 2, 2020 | 02:21 AM
wilde's Avatar
Default 03 Montero Limited cranks but won't start
Hello...was running fine one day. Sat for a couple of days and will not crank since...4 weeks of trying. No oil or coolant cross-contamination, and both are full. Battery freshly charged. I've tried it with throttle pedal all the way down, pumping midway, as well as untouched. Air filter is clean and I cleaned the throttle body and MAF sensor. Fuses are all good. I've also tried spraying starter fluid into the intake manifold...still no change.
I checked codes and these are present:
P0171 (freeze frame data attached)
P0401
P0431
P0421
Does anyone have any suggestions where to start and how? I've got a test light and voltmeter.
Thanks!
Old Oct 15, 2020 | 06:09 PM
Stubby's Avatar
Hello I’m having a similar problem with my montero. Mine will run in starter fluid but it will not stay running. I’ve changed fuel pump and Filter and still nothing. It’s getting spark but no fuel. I can hear the the pressure regulator clinking on and off but it seems to not be getting fuel. I was told to check the immobilizer as it may shut the fuel off. Sorry I have a montero sport not a limited.
Old Aug 10, 2021 | 08:06 PM
PalmSprings's Avatar
did you ever solve the starting problem?
Old May 29, 2023 | 08:01 PM
Sherwell's Avatar
Default No start
P0401
P0431
P0421
Thanks!
I'm having similar issues did you ever
figure out what was causing it
Hjp
Apr 5, 2021 02:20 PM
Warleader165
Jun 12, 2020 07:36 PM
wilde
Apr 2, 2020 01:49 AM
Bymp
Jul 20, 2010 10:23 AM
