1992 1.5 Mitsubishi Electrical Issues
Old Jun 8, 2009 | 01:07 PM
georides's Avatar
Default 1992 1.5 Mitsubishi Electrical Issues
Hi, first post here, but in need of some help, have a 1992 Eagle summit, it's the 1.5l Mitsu engine
Car was running fine until I left it in the sun over the summer, seemed to melt the ECU, so caused a no-start re no power to fuel pump. Drove it for a while with a hotwired fuel pump connection, nice check engine light for months, then changed to a grounded control relay connection which made it so I didn't need to turn on/off fuel when driving.
problems starting coming on soon after I changed cap wires rotor and put in some crazy bosch quad plugs that were given to me. I changed back to the autolites that are rec for this engine.
Had a slight miss on the highway a few weeks back, then problem became progressively worse, ECU seemed to shut off mid-street, then often a crank/no-start condition. I could hear the fuel pump running and cycling through the return line. Then it would finally cut back on, and I'd limp it to my destination.
This past week, decided to replace the ECU which I found the capacitors to be totally leaking (not to mention a poor soldering job as the car already had a rebuilt ECU previous owner. This fixed the fuel pump problem, so I didn't need to ground the control relay.
Still had the stalling out/cut out problems though, and found that moving the wires going into the distributor harness would click the ECU on/off (or at least would click click and make the idle servo click click.
Did a pretty pro solder/glue rebuild of the harness and car drove fine until TODAY, which I had planned to drive it 300 miles, cut out in the first 3 miles! tried shaking my distributor wires and no clicks, car finally decided to turn on, and I limped it home again.
I've ordered a new distributor as a last try, maybe there's a bad photo-diode in there, also plan on doing away with the control relay and replace it with a few radioshack parts.
WHAT ELSE, need some mitsu help here
Alpha7
Jan 29, 2009 02:31 AM
thebutcherr
4th Generation
Mar 16, 2008 02:39 PM
K*Rock
Mar 13, 2008 04:15 PM
edes101
Dec 4, 2007 11:23 AM
Mike21
Oct 10, 2006 07:45 PM
