1993 Mitsubishi Eclipse injector trouble
Old Feb 10, 2008 | 05:10 PM
jlgma's Avatar
Default 1993 Mitsubishi Eclipse injector trouble
Hello all, I am new in this forum and could use some help
I have a question I hope someone can maybe help me with.
I just bought a 93 mitsubishi eclipse with a 1.8L non turbo car. The trouble I am having is when you start the car it floods out #2 cylinder (but keeps running)so much gas it will run out of the exhaust. I tested the #2 injector plug with a noid light and it stays on (no blinking) all the rest seem fine. I replaced the fule injector. What do you think. No check engine light come on in car. What should I try next? Do you think it could be the ECU?
I hope someone can help me out.
Thank you,
Joe
Old Feb 12, 2008 | 09:19 AM
dsm1990gsx's Avatar
Default RE: 1993 Mitsubishi Eclipse injector trouble
If the noid light is staying on, you might have a shorted wire somwhere that is keeping the injector on. Did you ohm all the injectors? Check to see if #2 is in spec.
Old Feb 12, 2008 | 12:32 PM
jlgma's Avatar
Yes I ohm'ed all injectors and they are all within spec. With a grounded wire would that be within the wire loom or somewhere else? Can I ohm the plugs for the fuel injectors? If so what should they read.
Thank you,
Joe
Old Feb 13, 2008 | 01:44 PM
jlgma's Avatar
Ok I did a check on the plugs to the injectors with an ohm meter and the one that is not working only shows 4 ohms and the working ones show 40 ohms. Does this mean bronen wire somewere or could it still be the ECM?
Please help,
Joe
Old Feb 13, 2008 | 07:03 PM
dsm1990gsx's Avatar
If you want to check the harness side of the injectors, you have to dissconnect the injector connector and the 3 ecu connectors and ohm each wire from the injector to the ecu and you should get .5 ohms or less. Of you have a broken wire you wont have a reading or it will be very very high number.
If you have a noid light staying on I would focus on why its staying powered.
Old Feb 14, 2008 | 05:16 AM
jlgma's Avatar
I will try that, so should I check each wire by it self to a ground or per plug from injector? The reason I am checking for a broken wire is because I was told that it could be a cause to why the noid light was staying on and not pulsing like it should.
Thank you for your help I will keep this up to date with results.
Joe
Old Feb 14, 2008 | 11:01 AM
jlgma's Avatar
Well I was able to get a ECU pinout layout and did a test on the #1,#2,#3 and #4 pins for the fuel injectors and 1,3,and 4 were all the same at 54 ohms and #2 was at 24 ohms. So it sounds like it is the ECU that is giving me trouble. Am I missing anything?
Thank you,
Joe
Old Feb 14, 2008 | 01:09 PM
dsm1990gsx's Avatar
When your checking to see if a wire is good, each end of the harness has to disconnected.
Did you disconnect the ecu from the harness?
Old Feb 14, 2008 | 01:16 PM
dsm1990gsx's Avatar
On this diagram since you have a problem w/ the #2 injector I would check pin #2 to pin 60 at the ecu and see if that wire is good. B/c you already know pin one is good b/c the noid light stays on.
Old Feb 14, 2008 | 02:29 PM
jlgma's Avatar
I took the ECU out of the car to check it (the ECU). I checked 51,52,60 and 61 with a ohm meter. I used the #101 for ground and all tested the same except the #2 (#52 on diagram). I am going to check wiring next with everything unpluged. Am I doing this correctly? I sure hope so. When I checked wires unpluged from ECU and fuel injectors I had no reading from any of the plugs. (injector side)
Thank you,
Joe
