2000 rpm idle!
Old Feb 18, 2009 | 11:01 AM
cabldawg's Avatar
Default 2000 rpm idle!
My friend's car just jumped time and bent 8 valves. I put on a rebuilt head, new timing belt, water pump, tensioner, a/c belt/alternator belt/, all new gaskets, radiator, thermostat, and gave it a little shot of freon.
The car was running perfect for me after I completed the work. I ran it through several cycles of getting it up to operating temperature and cooling back down, and took it for a test drive. Everything was perfect. She took the car and a little while later she said that the idle was jumping up to 2000 rpms. What could cause this? It should be back here in a little while, and other than checking for a vacume hose that may have slipped off I don't realy know what to look for. It is not throwing any codes.
Thank you for your help!
Old Feb 18, 2009 | 11:37 AM
Vaccum hoses would be the first thing i would check as well. Other than that possibly a sensor that didnt get plugged back in.
Old Mar 6, 2009 | 02:01 PM
Conway3000gt's Avatar
it sounds like a vacuum leak or check the tps sensor its right on the throttle body and on my 3000gt its adjustable to just try monkeying with that first since it's easy
Diamante01
Dec 9, 2010 12:08 AM
ineedabin2
Oct 11, 2010 04:58 PM
Symyon
Nov 5, 2009 06:02 AM
Pribs
Mar 28, 2008 02:46 AM
racerx55
1st Generation
Dec 25, 2006 03:40 PM
