2002 Lancer RPM Trouble
Old Jul 26, 2008 | 11:18 PM
Abnatha's Avatar
Default 2002 Lancer RPM Trouble
Purchased a 2002 lancer rally edition a few months back. 75k miles, new timing belt, automatic transmission. Recently I've noticed something odd. Fuel economy seems to have been reduced, and when in drive at a stop light, the engine gives a pulsing feeling, with the rpm bouncing between 700 and 1200 at a regular rhythm. I plan on going on long distance drives with this car and want to figure out the problem and have it fixed soon.
Any advice would be greatly appreciated!
Thanks
Old Jul 27, 2008 | 12:05 AM
HandyPal's Avatar
Default RE: 2002 Lancer RPM Trouble
Do you have the same effect at idle? Is there Air conditioning on or off? Could be number of reasons... Throttle position sensor if exists, O2 sensor, air leaks into exhaust/inlet. I would start checking from these components.
Old Jul 27, 2008 | 03:00 AM
Abnatha's Avatar
During driving the air conditioning was off. The RPM only bounced while in drive or reverse. It stayed steady while in neutral.
Turning on the AC made the pulsing a bit more intense
Old Jul 28, 2008 | 10:33 PM
darknigh7th's Avatar
spark plugs??
Old Jul 31, 2008 | 09:01 PM
dsm1990gsx's Avatar
Do you have a check engine light? Could be a vacuum leak or an iac going bad.
beetlenut
Jan 22, 2017 06:11 AM
uli9595
May 5, 2013 09:19 PM
Sidsubishi
Apr 18, 2012 01:46 PM
antmag33
Feb 3, 2009 06:09 PM
ruslancer
Mar 5, 2005 02:59 PM
