3000gt is dead.....need help asap
Im in desperate need of help guys.....as i posted before the timing belt went on this car and wiped out the heads.Its a 93 3000gt( not twin turbo).I had a new belt,water pump,and rebuilt heads put on.After this the car wont start.The fuel pump was not running so i took it out and replaced it....still not working...checked power to the pump and there is none so i replaced the MFI relay,still no power.I checked all the fuses that i can and they all seem ok.I tried just running a wire from the battery to power the pump and it runs but the car wont even fire.It has spark,compression,and the plugs are wet with gas.I also checked the timing and #1 piston is at top,all marks line up.One odd thing is when you power up the pump it sounds like air hissing up by the fuel rail but gas is getting there.I checked and gas is coming through the line.Im out of ideas so any help will be greatly appreciated.Thanks...............
ronda1984
Aug 20, 2007 12:45 PM
