99 eclipse spyder no start
Old Jul 13, 2008 | 08:19 PM
alex500's Avatar
Default 99 eclipse spyder no start
I have a 1999 eclipse gs convertible with a 2.4 L engine, I just bought it in the auction and came without key, I made a regular key and it not start, SOMEONE KNOW IF THIS VEHICLE NEED A TRANSPORDER KEY ??, I check and there is no ground in the injectors,,, please help me.
Old Jul 13, 2008 | 08:28 PM
Default RE: 99 eclipse spyder no start
No transponder.
Oh, and please don't double post, thanks!
Old Jul 13, 2008 | 08:40 PM
alex500's Avatar
thank you, now that I know that this vehicle does not have a trasnporder key, what can cause that there is no ground in the fuel injection system ??
thank you
Old Jul 13, 2008 | 10:22 PM
I don't think that is your problem.
So when you turn the key you are getting all the dash lights etc?
Old Jul 13, 2008 | 10:33 PM
alex500's Avatar
Im getting all dash lights and the sparks are getting electricity but there is not ground in the fuel injectors, I put some starting fluid in the intake and it start for about 2-3 seconds so the problem is on the fuel injectors.I think that can be the engine computer or the crank sensor but im not sure
Old Jul 22, 2008 | 10:38 PM
HandyPal's Avatar
It's all screwed here, I can't post s**t!
Old Jul 23, 2008 | 07:47 AM
i would start by checking the fuel pump relays. Make sure you fuel pump is kicking on when your trying to start
Old Jul 23, 2008 | 10:03 PM
HandyPal's Avatar
Injectors get +12V and ground is pulsed by ECU. You need to trace from inj. to ECU. See if you get +12v as well.
Old Jul 24, 2008 | 08:41 PM
alex500's Avatar
I have 12v in the fuel injectors but I don't have ground, I change the PCM and this not resolve the problem, a friend tell me that could be the crank sensor. any help.
urnvs
Mar 6, 2013 10:25 AM
longbowdog
Nov 26, 2010 11:35 AM
alex500
Jul 13, 2008 08:25 PM
B.e.R.a.T
Jun 3, 2006 08:29 PM
theresa
Mar 19, 2006 12:19 AM
