Another ECU Question
OK, I've ruled out the ECU problem. I've installed two seperate ECUs from 2 Seperate GSTs and unless the planets have aligned and i found the 2 ECUs out there w. the same exact problem as me, There's something more than the ECU.
I'm going to try and install another MAF to see if that changes anything...we'll see.
gah, i'm so tired of this.
sorry to keep bumping this topic, but i had to mention.
The GSX ECU does work on the GSTs. All one has to do is Swtich wires 1&2 as well as 3&4. the GSX has an opposite CAS. But put in the new ECU and i'm still shooting out the same codes. Going to try new MAF soon... ::crosses fingers::
