Check Engine Light
Old Jan 17, 2008 | 09:53 PM
Scubba.steve's Avatar
Default Check Engine Light
Hey im having problems with my IAT sensor
P0112 Intake Air Temperature Circuit Low Input
Pops up whenever its put on the machine, which throws my check engine light on..
Well the sensor was just replaced. Im not understanding how or why its throwing low input code up..
Any thoughts guys?
thanks
Old Jan 18, 2008 | 07:02 AM
Default RE: Check Engine Light
does it come right back on after you reset the ecu (disconnect the battery). Or does it take a little. Im just wondering if this is an intermittant problem or something thats constant. Are there any performance issues?
Old Jan 18, 2008 | 10:53 AM
Comes back on within 5 minutes of clearing the code.
Everynow and then it takes it a minute to start up.
But when i unplug some sensor right beside,(Right where my ait intake goes in)It starts right up
Havent tried clearing the code then disconecting the battery though.
No performance issues, the car screams threw knoxville.
Old Jan 18, 2008 | 01:09 PM
dsm1990gsx's Avatar
Check the wiring for the sensor. You might have a broken wire to the pcm.
Old Jan 20, 2008 | 05:03 PM
All wiring looks fine, unless 1 is broken off inside
Old Jan 20, 2008 | 05:33 PM
dsm1990gsx's Avatar
Lol you cant tell a wire is good by looking at it, try ohming the wiring from the sensor to the ecu.
Old Jan 20, 2008 | 06:19 PM
lhausi2's Avatar
if you get a haynes manual it'll tell you how to test the sensors if you dunno how which it sounds like
Old Jan 20, 2008 | 08:57 PM
Thank you, i have the haynes manual, took less than 5minutes schimming through it and found what i needed.
Now just needa meter
Old Jan 23, 2008 | 08:23 PM
lhausi2's Avatar
you can buy a half way decent one at napa or autozone , for like 40 bucks, and you can use it for a whole lot more than just resistance
Old Jan 23, 2008 | 10:15 PM
well i took the car to midas, they told me that it was a sensor that was supposed to be on my cold air intake,yet they couldnt find the wire and said someone had ripped it out.I think they are full of $hit. Im just going to replace the one i have.
