Check Engine Light
Old Jan 23, 2008 | 10:27 PM
lhausi2's Avatar
Default RE: Check Engine Light
Yeah I can't talk, cuz there's a midas right next to my work. And they usually don't bs ppl, but the one u went to might be different idk. Check the plug and see if you bent one of the connectors inside the plug. Cuz its happened and no1 thinks of it
Old Jan 27, 2008 | 12:09 PM
Scubba.steve's Avatar
Welli l finnaly had time to check this problem out. Iunpluged the sensor, wiped it off really good. Someone had spliced a new connector on this car. Pulled off all the electrical tape around the splicing.......the wires were barley touching each other. So i cut the wires and reconnected them and wraped them with that heat shrink tubing. What ya know the car fired on the first time and my check engine light was gone. All my worries over a **** poor wiring job.
Old Jan 27, 2008 | 06:02 PM
Haha ok i spoke too soon....Well the car did fine, and light stayed off but after 30minutes of driving the light came back on and stayed on until i turned the vehicle off. Seem's the light only comes on when car is running normal temperature. Is this a problem with bad sensors or bad wiring?
Old Feb 13, 2008 | 10:52 AM
Ok im starting to figures this out. First start car fires right up, but once im driving and the engine heats up the light comes on. After i shut it off its hard to startback up. Is this just my sensor bad or do i have other problems awaiting to be found?
Thanks Guys
guyjg
Nov 13, 2021 03:27 PM
SpyderGST
Dec 27, 2014 06:50 PM
pgb205
Jun 4, 2009 10:40 PM
c577
Oct 16, 2007 12:03 AM
rkerner
Jul 22, 2005 01:04 PM
