ECU Smokes
Old Aug 30, 2009 | 02:16 PM
reptile80's Avatar
Default ECU Smokes
I have a 99 eclipse, it was parked and then started after sitting awhile. When we tried to start it, it smoked the ECU (smoke comes out of the plugs to the ECU) I checked all the wires to the ECU and they all look good. I am just wondering what could cause this to happen. I cannot see what is fried on the board due to all the silicon like coating on it. Everything else seems to be working, I do not hear the fuel pump when I try to start the car though. It is a non turbo, 5 speed manual.
Any help would be appreciated.
Old Aug 30, 2009 | 08:49 PM
Open up the ECU and inspect it.
Old Aug 31, 2009 | 08:53 AM
reptile80's Avatar
I opened it up and all I can see is where the heatsink burned and it melted some of the silicon like gel.
Old Aug 31, 2009 | 06:32 PM
So there are no leaking capacitors?
Old Sep 1, 2009 | 12:44 PM
reptile80's Avatar
I cannot see the board very well it is still covered with the silicon like covering that appears to be about 1/2 inch thick. But from what i can gather it does appear to be the caps, but not 100% positive.
Any suggestions?
Old Sep 1, 2009 | 01:16 PM
your gonna need to replace the ecu.
Old Sep 1, 2009 | 08:46 PM
reptile80's Avatar
You all think it was just a bad ECU then? Should be ok to replace it? Sorry for all the questions, just wanting to make sure before I put the ECU in it.
mrtony8
Mar 11, 2007 11:48 PM
katinkid
Mar 2, 2007 03:37 PM
katinkid
Mar 1, 2007 09:00 AM
DixonsGst
Oct 18, 2006 03:53 PM
STACYYY23
Jan 18, 2005 10:23 PM
