Ecu/wiring harness question
Old Sep 17, 2007 | 09:49 AM
kmauger07's Avatar
Default Ecu/wiring harness question
i have a 96 gs with i believe to be a 97 model motor..the 420a that is blown..im buying a motor from someone and believe the new motor is a 96 model..will the ecu and wiring harness still hookup okay or will i have to buy the different one..just curious cause the seller told me this.
Old Sep 17, 2007 | 11:27 AM
Default RE: Ecu/wiring harness question
As long as you are staying without whatever type transmission you have (manual/auto) and the engine you have is the same one (420a) then it should be a direct swap. No new ecu necessary
Old Sep 17, 2007 | 11:30 AM
kmauger07's Avatar
alrighty thanks..i thought it had something to do with the tranny but that works..i am staying for now so itll be an easy swap..thanks again
natewesselink
1st Generation
Aug 7, 2007 02:41 PM
im2f4st4u
Feb 16, 2007 08:08 PM
bluballz07
Oct 4, 2006 07:48 PM
Mac_attack769
Sep 6, 2006 04:41 PM
AllThingsDSM
Feb 8, 2006 01:33 PM
