idle air control valve
Old Feb 12, 2005 | 06:48 PM
1398spdr's Avatar
Default idle air control valve
anybody know how to test one, where it is located and how hard to change......... thanks for the help
Old Feb 15, 2005 | 01:20 PM
1398spdr's Avatar
Default RE: idle air control valve
i couldnt find anything in the vfaq about this........... car doesnt seem to have any symptoms, but ses light is on, had the mechanic get the code and clear the computer, came back 2 days later, any ideas...........
Old Mar 15, 2005 | 07:02 PM
vertstanggt's Avatar
it is uaually on the throttle body. I'll go run out and see if I can spot it on mine. Alright, on my 97 GST the TPS is on the front of the TB, there's a sensor housing on the botton right under the intake tube and then there's also vacume lines going to a couple things on the firewall. None of these look like the IACV's I've seen in the past so I'm not sure. So you don't have any problems but the computer's reading that it's bad?
Old Mar 16, 2005 | 07:29 AM
1398spdr's Avatar
yea, its starting to run a little high at idle, so i think its just a warning light..........
Usc529
Sep 5, 2010 06:29 PM
rudyman
Nov 4, 2008 01:05 AM
MitsuMitsu
Apr 30, 2008 11:36 AM
94GalantLS
Mar 29, 2006 01:40 AM
blkdoutek
Jan 25, 2006 08:58 PM
