injector Q
ok i installed an A/f ratio gage! and i seems i am running really lean! it's a faze a/f gage and even when i am excelerating it barely goes in to the yelllow. is this a bad thing!
my buddy tells me that when i am excelling hard it should run rich! and when i am on decell it should fall back down and run lean.
could some one give me the heads up on all of this!
would bigger injectors and a high flow pump bump my power and make my car run better!
thanks
bud
thanks
bud
because hes describing with colors and not #'s im assuming narrowband. Now yes you should be hitting in the green under full boost. My guess is either the guage is hooked up wrong or you have a clogged fuel filter or injectors
ORIGINAL: Sebba
Ergh.. thats a narrow band. What it displays means absolutly NOTHING. You need to get a wideband
But how do you know what its calibrated to? It could be calibrated to ANYTHING?!?!?!?!
I have a friend that had a Renault 5 GT Turbo and he had a wideband and a narrowband. The wideband showed the normal a/f ratio and the narrowband said rich and never moved from that.
What im trying to say is they dont actually indicate anything unless they have been calibrated to your car.
