injector Q
Old Oct 30, 2006 | 10:30 PM
bud660r's Avatar
Default injector Q
ok i installed an A/f ratio gage! and i seems i am running really lean! it's a faze a/f gage and even when i am excelerating it barely goes in to the yelllow. is this a bad thing!
my buddy tells me that when i am excelling hard it should run rich! and when i am on decell it should fall back down and run lean.
could some one give me the heads up on all of this!
would bigger injectors and a high flow pump bump my power and make my car run better!
thanks
bud
Old Oct 31, 2006 | 01:36 AM
Default RE: injector Q
Did you buy a narrowband?
Can i see a pic of this gauge?
Old Oct 31, 2006 | 09:35 AM
because hes describing with colors and not #'s im assuming narrowband. Now yes you should be hitting in the green under full boost. My guess is either the guage is hooked up wrong or you have a clogged fuel filter or injectors
Old Oct 31, 2006 | 02:25 PM
All narrowbands are different. It dosent actually mean a single friggin thing! The gauge is hooked up fine... it just sucks.
Old Oct 31, 2006 | 08:54 PM
bud660r's Avatar
ya i am thinkin it's bad filter and injectors. but sense i am messing with the fuel i am going to replace the pump to
Old Oct 31, 2006 | 08:57 PM
do yo have a wideband or a narrowband?
Old Oct 31, 2006 | 09:52 PM
bud660r's Avatar
not sure! i has colored notches no numbers!
Old Oct 31, 2006 | 10:48 PM
Ergh.. thats a narrow band. What it displays means absolutly NOTHING. You need to get a wideband
Old Nov 1, 2006 | 09:44 AM
ORIGINAL: Sebba
sebba it still atributes to something though. It doesnt erase the fact that he should be hitting green at full boost. I admit its a POS and really gives you no help on tuning a car, but it does give a reading, and right now his is too lean. When i had my talon i got the crappy narrowband, not knowing any better, and even with how ****ty my car was it would still hit green
Old Nov 1, 2006 | 12:55 PM
But how do you know what its calibrated to? It could be calibrated to ANYTHING?!?!?!?!
I have a friend that had a Renault 5 GT Turbo and he had a wideband and a narrowband. The wideband showed the normal a/f ratio and the narrowband said rich and never moved from that.
What im trying to say is they dont actually indicate anything unless they have been calibrated to your car.
