Installing a new O2 sensor
Old Aug 22, 2007 | 11:20 PM
Azazel's Avatar
Default Installing a new O2 sensor
I have a new O2 sensor I need to install in my '97 Eclipse, 2.0 non-turbo. Installing to try to fix a "System Too Lean (Bank 1)" error and really low mpg.
Do I need to replace the upstream or downstream sensor, and how do I do it? Appreciate any pointers...
Old Aug 23, 2007 | 01:23 AM
silvercoupe97's Avatar
Default RE: Installing a new O2 sensor
That would be the first o2 sensor after the exhaust manifold. You need either an open ended wrench or an o2 socket to remove it. You'll also need anti-seize for the o2 threads, unless it comes with the o2 sensor. Anti-seize is highly recommended bud
Oh, forgot to mention...I suggest an OEM replacement over the universal just to keep from getting confused with what wires go where...most of them aren't very clear to folks who've never done it before.
Old Aug 24, 2007 | 10:46 AM
Azazel's Avatar
Thanks! Just so I don't do something dumb, is the O2 sensor highlighted in blue below the right one?
Thanks!
monkeyman
Jan 22, 2013 06:36 PM
wbrod
Nov 24, 2005 02:40 PM
bcolins
Aug 15, 2005 12:52 PM
ilcaa
Feb 26, 2005 07:20 PM
RALLIART22
Jan 10, 2005 02:39 AM
