just purchased a2001 eclipse 2.4
Old Sep 12, 2013 | 10:14 PM
emmirox's Avatar
Default just purchased a2001 eclipse 2.4
Have had it for about a month and check engine light is on with code p0455.my gas cap is tight.I went as far as putting light coat of grease on cap ruber and tighten till 3 clicks heard and checked filler nozzle for grease transfer, no signs of any leaks.the filler neck underneath has severe rust.no noticeable leaks.I'm a diy guy and have access to snap on scanner, limited use with it,is there a evap static sysyem test I can run without having to wait for ecu to run its test and hopefully notice something in a blink of an eye? And is there a common concern with these? Vent solenoid...purge solenoid? Wire concern? Any help would be appreciated.
Old Sep 12, 2013 | 11:20 PM
Typical crap for a 10+ year old vehicle.
I would take it somewhere and have it smoked, that'll show where any leaks are.
98GTX
Aug 11, 2014 02:36 AM
ktmk36
Aug 7, 2011 02:40 PM
ktmk36
Jul 25, 2011 08:47 PM
benjaminws
Aug 29, 2008 11:36 PM
XTREME
Mar 31, 2006 05:34 PM
