No fuel to cylinders! HELP!?!?!???
Old Nov 7, 2019 | 04:33 PM
Souhradaj360's Avatar
Default No fuel to cylinders! HELP!?!?!???
2009 Eclipse 2.4
I replaced the timing belt/water pump/belt tensioner and pulleys. I started the car and it ran at idle and revved nicely in the garage. I Put it in gear and drove out of my garage and onto the slightly inclined driveway where it sputtered and died. Sprayed starting fluid into the intake and it runs fine so I know it’s getting spark but for some reason it’s not getting fuel. Fuel pump is receiving voltage during start up. Fuel pump is running during start up. But for some reason there’s no fuel getting to the cylinders. I replace the fuel pump but still have the same problem. Is there anything that would cause all four injectors to stop working at the same time?
spyder01
May 14, 2023 06:46 AM
xp8ntballkid309x
Jul 13, 2007 04:15 PM
davidmitsusrock
Nov 3, 2006 01:09 AM
astraldweller
Nov 8, 2005 12:20 PM
CarNewb
1st Generation
Jun 30, 2005 03:41 PM
