Refueling
Old Sep 4, 2008 | 11:30 PM
fred c's Avatar
Default Refueling
I have a 2002 Montero Limited. When refueling an almost empty fuel tank after about 8 gallons the pump kicks off because the fuel
is all the way to the top of the neck,after removing the pump nozzle the fuel resends very slowly and then you can add serveral
gallons more and the same thing happens again. I suspect a problem with the vapor recovery system. Can anyonegive any other suggestion
on this, and also where is the charcoal canister for this system located?
thanks Fred
BrianB
Sep 15, 2015 08:41 PM
