won't start
Old May 2, 2009 | 10:28 PM
2000eclipse's Avatar
Default won't start
My mom has a 2000 Eclipse that has been throwing a code for2nd cylinder misfire. It died today. I replaced the wires and fuel pump. I tested the 3 front wires and 2 were bad. Also checked the relays. Still need to recheck the codes. There are so many sensors and wires, its a little overwhelming. One suggestion could go a lomg way. Thanks.
Old May 3, 2009 | 09:29 PM
dsm1990gsx's Avatar
Well did you check for fuel and spark?
Old May 8, 2009 | 02:26 PM
Asilus's Avatar
2nd cylenders spark may be fowled, broken, plug wire bad, injector dirty, not working, throw gas cleaner, replace plugs and wires is the norm maintanance
Old May 10, 2009 | 12:25 AM
Default help
I've now replaced the plugs, wires, valve cover gaskets, and tube seals. I thought it was just a simple tune-up because I tested two bad wires on the front and saw two leaking tube seals on the back (that I didn't test). Newer cam sensor, cap, and rotor. I'm thinking that I need to trace back to before the cap, but that's pretty much where my knowledge ends. Could be a sensor or something. I don't know.
Old May 10, 2009 | 10:49 AM
dsm1990gsx's Avatar
So have you done this?
mysticrythms
Mar 19, 2014 08:17 PM
Flipz
Dec 12, 2004 04:51 PM
truck2121
Aug 17, 2004 11:15 AM
workmanls
Jul 23, 2004 04:58 PM
cbjacer
Jun 26, 2004 04:45 AM
