A lil cell video of my car..
Old May 21, 2007 | 10:41 PM
jlh077464's Avatar
Default A lil cell video of my car..
Well guys. Every sice I installed my afc neo. My car smokes heavily, mostly white smoke and some black. Also you cant rev it while idling. It like bogs down and just wont rev up. I need some help here. I thought I had bought and done everything i needed 2 be able 2 drive it. Hit me up with some ideas!?
My car.
Old May 22, 2007 | 09:17 AM
jlh077464's Avatar
Default RE: A lil cell video of my car..
thanx for tha edit, but any replies?
Old May 22, 2007 | 09:23 AM
Did you tune it? LOL
Old May 22, 2007 | 11:30 AM
50ul }{4ck3r's Avatar
Is That normal? lol...looks like it is not tuned at all
Old May 22, 2007 | 11:42 AM
jlh077464's Avatar
.....Thats the problem. I'm just tryin 2 get a mild tune 2 get me to an exhaust shop 2 get my bung welded in my downpipe for my wideband so I can do some fine tuning. No matter what i seem 2 set it on on low throttle it does this. I haven't even drove it. I don't want to till i at least get it 2 idle smooth and not smoke.
Old May 22, 2007 | 12:41 PM
The smoke is just running super rich i believe.
You should not have installed it if you didnt have a wideband.... not smart
Old May 22, 2007 | 08:47 PM
jlh077464's Avatar
How is that not smart?....a little tune is better than no tune?...don't ya think?...I have an aem eugo. Plus EGT guage(which is installed). I just dont have the bung welded in my downpipe. Any ideas on what to do?
Old May 22, 2007 | 08:50 PM
jlh077464's Avatar
Low Setting:
1K +39 2K +13 3K + 6 4K +3 5K +3 5.5K + 3 6K +3 7K +3 High Setting:
1K -10 2K -10 3K -10 4K -10 5K -3 5.5K +6 6K +8 7K +8 TH-Point
Lo 30% Hi 80%
...this is pretty close to what it was set @ during that video.
Old May 22, 2007 | 08:56 PM
silvercoupe97's Avatar
Hey Josh, do me a favor and post your mods again. I'll do some research and see what I can find for you. I don't have an AFC so I couldn't decipher that, but let me see what I can find.
Sorry I didn't post after the fix, I didn't have time though.
Old May 22, 2007 | 09:05 PM
jlh077464's Avatar
Man that's no problem. I'm just really seeking help. You help me more than you know. My neo would still be in my room instead of installed if it wasnt for you.
* All on a 1st Gen 7 bolt. *
1G BOV
2G Tubular manifold (ebay BS)
NGK R1 SPARK PLUGS (1 STEP COLDER)
FIC? 650CC FUEL INJECTORS
ACT 2600LB CLUTCH KIT
T3/T4 50 trim(ebay BS)...until it poops out..then ill buy a good one.
EVO 3 OIL FILTER HOUSING
ARP HEAD STUDS
External oil cooler
High volume fuel rail (Ebay BS)
24x12x3 FMIC (Ebay core only)
turbosmart dual stage gated boost control
EGT kit(had a shop install it, Still can't figure out where tha crap they tapped it in @.)
255 Walbro high pressure fuel pump
Aeromotive FPR kit
Apexi Turbo timer (my cars alarm does not get along with @ all)
AEM UEGO
AFC Neo
BLOCK=
HOT TANKED
PRESSURE TESTED
LINE HONED
BALANCE SHAFT ELIMINATOR KIT
FREEZE PLUGS
2G 8.5.1 PISTONS (.20 OVER)
PISTON RINGS (.20 OVER)
ARP MAIN STUDS
ARP ROD BOLTS
3 ANGLE VALVE JOB
MILD PORTING TO SMOOTH BOWLS
* I know you didnt need a lot of this probably but I had my old mod list already saved 2 my computer, so I just added what I bought since then. So so so sorry about the caps lock., thats the way I had it saved.
*Also the engine itself since the rebuild has about 400 miles on it. The turbo and the rest of the mods, Maybe 40 miles @ the most.
