Listen to this noise... can anyone help me?
Old Apr 11, 2008 | 09:56 AM
4g93myrage's Avatar
Default Listen to this noise... can anyone help me?
Since this is the video area of the forums, I figured I would post this here. I am hearing a wierd clicking sound when driving my car. And I need some help trying to identify the problem at hand. If anyone could possibly help me, I would be very appreciative!!
http://s209.photobucket.com/albums/b...t=MOV00001.flv
Old Apr 11, 2008 | 11:22 AM
dsm1990gsx's Avatar
Default RE: Listen to this noise... can anyone help me?
Sounds like an axle, I only heard it while you were making turns. Take a peek at the axle boots, if they're ripped thats your problem.
Old Apr 11, 2008 | 09:56 PM
atown420's Avatar
what was the sound during idle? when he jumped in the car. thats a nice ad though. howd he get in
Old Apr 13, 2008 | 10:05 AM
dsm1990gsx's Avatar
ORIGINAL: atown420
I didnt hear anything at idle and for the ad's they came out of nowhere,they're getting annoying.
Old Apr 21, 2008 | 04:41 PM
Hyphy Crunk's Avatar
I had the same problem.
It ended up being a combination of a worn axles, wheel bearings, and tie rod inners.
most likely an axle or tie rod problem tho, check your axle boot like dsm1990gsx says.
and also jack up your front end, and with the car on secure jack stands check for play in the tie rod ends either, most likely inner.
make sure you take the keys out and lock the wheel in one position.
jtherrien69
Feb 21, 2009 07:40 AM
50ul }{4ck3r
May 15, 2007 09:24 PM
silvercoupe97
Apr 30, 2007 11:05 AM
anthony_piaa
Mar 30, 2007 11:58 PM
ILoveTurks
Nov 25, 2005 04:04 AM
