09 Galant Ralliart and possible front suspension problem - please help
Old Oct 30, 2013 | 01:46 AM
Lindy09's Avatar
Default 09 Galant Ralliart and possible front suspension problem - please help
I have an 09 Galant Ralliart with 72,000 miles. The drivers side front end is making a creaking noise when I go over bumps and also when the car levels out after going up my steep driveway. Also another issue I am having is a creaking noise when I shift from park to drive and reverse. Any ideas what might be going on?
Old Oct 30, 2013 | 03:00 AM
Control arm bushings are worn out. You may need to replace the entire control arm if the bushings aren't available separate.
Your motor mounts are also likely shot.
inandout
Mar 18, 2021 03:48 PM
KenAEM
Nov 18, 2009 12:12 PM
99galant
Mar 20, 2007 02:50 AM
xtreme49
Jun 20, 2006 11:54 PM
RakMej
Jan 27, 2006 02:35 AM
