2001 Montero XLS. Need Help
Old Jan 22, 2010 | 08:32 AM
D.P.'s Avatar
Question 2001 Montero XLS. Need Help
First post. I could not find any thread regarding suspension for a 2001 Montero XLS suspension. They may be out there, I just could not find them. This is my daily driver with 113,000 miles. The suspension is original. The shocks and struts are shot. I figure as long as I am in there replacing the shocks and struts, I might as well change anything else that needs changing. Problem is there is a lot more under there than a regular auto so I am at a complete loss as to where to start. What should I look at changing and is there a reliable online source to buy it from that you could recommend.
I am not looking to do anything fancy. I just want the ride back to original. I would like to do the entire thing in poly if possible.
Thank you.
Old Feb 19, 2010 | 11:12 PM
254chamorro's Avatar
Thank you.
Might be to late but thought I post something since no one on this damn forum likes to help anyone. But go to http://www.autopartswarehouse.com I found that sight useful. I would change the shocks and bushings if they look bad, while you down there you should grease up everything you can, find the nipple and make sure its the right stuff.
bstarski
Feb 27, 2018 04:25 PM
paparoach
Dec 22, 2013 06:14 PM
mnewland00
Dec 23, 2010 05:31 PM
bstarski
Nov 17, 2010 02:18 PM
ttplusd
Feb 2, 2009 06:26 PM
