Coilovers
Old May 23, 2006 | 04:35 PM
Dragonslayer's Avatar
Default Coilovers
Hey guys, i have some bomz racing coilovers that i plan to put on my 1999 eclipse rs, i would like to lower it about 2 inchs, is that an extreme drop so that i will need new shocks and a chamber kit? Also, how low can i lower it so that i don't need to buy new shocks than stock? Thanks guys.
Old May 23, 2006 | 04:47 PM
Default RE: Coilovers
well i just want to start out by saying that i woudnt have got those cuz im pretty sure your gonna get a bad ride quality but with that being said:
I recommend getting new shocks and struts for the better ride, however if you dont want to do that then i would try and stay around 1.5" so that you wont need a camber kit. I think if you were to go to 2" then you might be needing one. But some cars are different then others. Youd really have to just put them one and play with it and check for negative camber to see if you need it or not.
Lunar_Eclipse
Aug 28, 2005 11:56 PM
whitestallion10
Jan 28, 2005 04:38 PM
99eclipseguy
Nov 16, 2004 02:00 AM
unplugged_nate
Jul 25, 2004 03:04 AM
theguy387
Feb 23, 2004 03:36 AM
