FWD suspension mods
Old Jun 12, 2008 | 08:57 PM
YUPinmyGST's Avatar
Default FWD suspension mods
Ok, so I have 98 GS-T maxing out the 14B power-wise, and can't get a very good time but the trap is pretty good for pump gas. I'm gonna be putting a holset turbo in it soon and the dyno should be showing me numbers in the 500 range on race gas, it'd suck to make that kind of power and run 13's. I need some tips on what to do to get this damn thing off the line. I ran a 14.1 at 106mph with nothing better than a 2.3 60 ft time before the motor blew. I'm thinking about getting some super hard rear shocks and some slicks in the front. Anyone else find anything good? Also, I've only been at the track 3 times, so 60 foot should improve as I learn to launch better.
Old Jun 12, 2008 | 09:15 PM
Default RE: FWD suspension mods
Good stiff coilovers, LSD, and big *** slicks. Should do the trick
Are you that DSM girl from before?
Old Jun 12, 2008 | 09:21 PM
YUPinmyGST's Avatar
I am a girl, I don't think a "dsm girl" is a very good label for anyone lol.
Old Jun 12, 2008 | 09:31 PM
Sure it is!
Old Jul 6, 2008 | 08:59 AM
4Grim's Avatar
A good set of 1 piece coilovers or some sleeve type coilovers with KYB AGX's.
Mid damper setting up front and stiffest setting for the rear dampers on the rear
Motor mount inserts (Polyurethane fill mod from Home Depot/Lowes / Energy suspension / Prothane) to prevent "wheel hop"
Some good slicks or some soft rubber z rated tires with low tire pressure if you are on a budget.
2 step/stutterbox
Practice
[8D]
Old Sep 29, 2008 | 02:29 AM
9mm's Avatar
9mm
Sebba Im new here but you are all over the girls man. last two links have been with you trying to pull a fast one. lol im just playing so you got any advice for my problem.
Old Sep 29, 2008 | 06:50 AM
i dont think you want to put a 2 step on a FWD car. And definetly need quaife LSD to even think about trying to run 500hp on a FWD car. That is just insane.
fasteriwas
Jan 15, 2007 03:49 AM
twinstealthytalon
1st Generation
Oct 12, 2005 10:53 PM
Jgsnismoser
Oct 5, 2005 11:13 PM
Galantz01
Feb 19, 2005 04:43 AM
toaster_power
Mar 2, 2004 09:13 PM
