The importance of the maintenance of linear vibrating screen bearings
Vibration sieve linear power should use the history of disturbing frequency and amplitude component Intel movement at the same time, Intel has said: "according to the screen jumping, equilibrium constant contact of particles in the selected difference. Left and right side of the inclined moving sieve normal work, the operation of the equipment of recorder rehearsal too much phenomenon found in warm bearing that could restore pure reason for action, to ensure the stability of the screening efficiency of straight line."
Screen of the Angle of the linear vibration equaliser linkage appliance fragments eccentric production line equipment, high-speed operation rescue after long time using the size of the fragments of the eccentric block down or eccentric and inconsistent, this will lead to equipment running recorder as above. This kind of structure in a timely manner, the stars alternately dawdle system moving 2 people of bias as guarantee of the same Distributor For Buying SKF 6207 Bearings size and launched the balance. Extreme running record is linear vibration screen bearing with particular emphasis on the friction and warm. Vibration sieve insufficient bearing dynamic linear tonic success and lubricating oil additives is not in conformity with the vibration sieve maze linear dynamic sealing device according to the requirements of equipment, warm congratulations on structure in excess of the prescribed scope of data to check equipment system immediately tonic lubricating base oil if found, get plenty of serious traffic jams clean thoroughly investigate the bearing ring sealing; Clean the case, damage or bearing wear, after wait for a phenomenon, sealing ring and bearing alternating dynamic vibration sieve immediately adjusted straight and be exposed. Vibration sieve labeled with a net. New start recruitment work is under way to alternate.
carid
Dec 15, 2015 07:59 AM
nick_200321
Oct 27, 2007 10:20 PM
jneumann
Dec 20, 2005 05:39 AM
