Montero Driveline Vibration
Old Oct 13, 2011 | 01:21 PM
mpasman's Avatar
Unhappy Montero Driveline Vibration
HI there ive got a 1996 Montero LS(3.0l) At 85km/hr ive got a mad vibration that shakes the whole vehicle. Recent repairs are as follows
Complete rear brakes
Both driveshafts have new ujoints and have been balanced at a driveline shop
New Tires
Front Shocks
On a hoist(suspension loaded and unloaded) vibration cannot be duplicated.
This is driving me crazy so any help would be appreciated!
Thanks, Mike
Old Oct 13, 2011 | 10:12 PM
mxmikie's Avatar
trans mount or trailing arm bushing
Old Oct 14, 2011 | 10:58 AM
mpasman's Avatar
Trans mounts are hammered out and on order. Thanks for the reply! Will look into the trailing arm bushings as well
Old Nov 22, 2011 | 02:57 PM
mpasman's Avatar
Thumbs down
Just installed new trailing arm bushings along with the new trans mount. Vibration STILL present. Got a reply from another forum regarding the rear driveshatf insulation coming loosew from the inside. This guy had same problem i am experiancing in 2different vehicles. New driveshaft fixed both. Will be possibly trying to drive without rear shaft or trying to locate new one in the mean time. Thanks for all the replys!
Old Jul 20, 2012 | 09:26 PM
jaguarxk8's Avatar
Well guys after spending hundred of dollars on drive shaft; transmission fluid change; rear end fluid change; dealership could tn find problem; went to several shop just throwing money after money. Finally I went to this small spanish shop and the owner drove the thruck; came back and then drove again. Finally after crow barring everthing under chasis they found all the rear upper and lower control arm bushing were shot. I must have spent a thousand dollars are more trying to solve the intermittment vibration problem. All for 48 dollars. Then the labor is only $80.
Problem now is that the lower rear bushing is 15 bucks but the rear uppper is sold as the entire arm for $502. Need solution to maybe finding bushing that will work. Im not paying $502 for the arm w/ pre-installed bushing. Pleaee help. 2003 montero. Will I be able to find bushing somewhere that will work. What about previous years where rear upper businging could be pruchased
Old Jul 21, 2012 | 03:19 PM
mxmikie's Avatar
send me the specs of the bushings i be able to make you some in urethans mxmikie@yahoo.com
Old Jul 24, 2012 | 04:16 AM
DarkPoet's Avatar
New Tires
Front Shocks
Thanks, Mike
I had a similar issue with my previous car. The problem ended up being a combination of the front tires being separated due to a poor alignment as well as some front outer tie-rod issues.
Have your tires looked over again to look for any abnormal signs of wear and tear that might be caused due to alignment issues. Also have a look at your tie-rods, make sure they're not leaking and that there's no excessive play which CAN cause a nasty shake.
GPE
Oct 9, 2018 02:39 PM
antmag33
28
Jul 28, 2017 09:16 AM
johnoutdoors
Nov 8, 2010 12:15 PM
tico1972
Sep 28, 2009 09:24 AM
Navyboy002
11
Mar 29, 2008 12:15 AM
