engine surges at idle and has high idle please help
Old 08-28-2006, 10:04 PM
yamahablaster8230's Avatar
Default engine surges at idle and has high idle please help
i just purchaced a new motor for my 95 eclipse gs and we fired it up and it surges at idle it idles at 2500 and when it heats up it idles down then idles up agian to like 3000 the oil pressure is fine and the throttle cable and everythng is good. there is a light on in the dash it looks like low coolant mabe? its on the right side but i dont know what it means either just looking for some help if any one could help me i would appreciate it thanks.
Old 08-29-2006, 02:19 AM
Nubiebubie_GSX's Avatar
Default RE: engine surges at idle and has high idle please help
Well when i had high idle i had a vac leak in my intake. Also when i try to reinstall the cruise cable and it was to tight. That all i can say and suggest.
Old 08-29-2006, 09:28 AM
do you have any CEL? Could be a bad throttle position sensor. or maybe your base idle is set off
mitsiv3000
09-02-2013 04:16 AM
streetenvy
03-01-2011 08:08 PM
randya
02-09-2009 12:53 AM
infinity8x3
01-17-2008 12:56 PM
xclr8
09-20-2005 10:45 PM
Quick Reply: engine surges at idle and has high idle please help
