mirage 1.5 starts bad and surges
Old Sep 20, 2005 | 10:45 PM
xclr8's Avatar
Default mirage 1.5 starts bad and surges
hi all
i have a 97 mirage 1.5 ltr. that has two issues i believe may be related.
first, about 70% of the time, i will go to start it and it sputters so bad it sounds like it's only running on 2 cylinders. (not exagerating), and if i pump the gas pedal several times it stops doing it and won't do it again until the next cold re-start. the other 30% of the time it starts normally.
second, the car always has a slight surge to it, in all ranges of speed.
here is list of stuff i've changed without making any difference to these problems:
wires, plugs, air filter, cap, rotor, cleaned out throttle flap with spray, run injecter cleaner through tank several times, timing belts
do these vehicles have a choke of some kind?
thanks for any help
xclr8
mitsiv3000
Sep 2, 2013 04:16 AM
randya
Feb 9, 2009 12:53 AM
96420ars
Nov 17, 2008 04:58 PM
infinity8x3
Jan 17, 2008 12:56 PM
yamahablaster8230
Aug 29, 2006 09:28 AM
