totally lost......NEED HELP PLEASE.....
Old 09-26-2012, 07:01 PM
mitsnewbie68's Avatar
Default totally lost......NEED HELP PLEASE.....
got a 93 3000gt....had new heads,timing belt,fuel pump,water pump put on,new computer....has no power to fuel pump.swapped out mfi relay with another one and still nothing.checked fuses and all seem ok.pump runs if hooked directly to battery.could there be an issue with anti theft???any other ideas or help is appreciated.thanks
Old 09-26-2012, 07:54 PM
also note that the car wont start when i hook fuel pump up directly to battery either.it just turns over but it does have compression and spark.
Old 09-27-2012, 11:42 PM
mxmikie's Avatar
any burnt caps in the ecm ????
Old 09-29-2012, 03:14 PM
its brand new.....
Old 09-30-2012, 12:55 AM
mxmikie's Avatar
Originally Posted by mitsnewbie68
its brand new.....
what does that mean ????
Old 09-30-2012, 12:06 PM
that means the ecm is brand new like i said originaly....dont know what else to check for so thats why i asked on here.
Old 10-01-2012, 08:57 PM
mxmikie's Avatar
cause it is new dont mean that it is good check it for burnt caps
Old 10-03-2012, 09:52 AM
toddrs93's Avatar
did it run before all this?
You need to see if fuel is actually spraying. when your cranking it with the fuel pump getting power, pull the plugs and see if they are wet from fuel. Make sure timing is set correctly. fuel pump gets signal from the mfi which gets signal from the ecu and thats it. if its a tt there is also a fuel pump relay and resistor up under the engine bay fuse box that could be bad.
mda185
07-14-2013 06:42 PM
kenuck
04-01-2013 04:09 PM
joeuspe
08-12-2011 07:42 PM
angel73
06-21-2011 12:17 PM
jshem746
32
11-06-2007 05:21 AM
Quick Reply: totally lost......NEED HELP PLEASE.....
