Oil on tops and bottoms of spark plugs
Old May 23, 2013 | 01:16 PM
Check your base timing
Glad to see the problem has been solved.
Old May 23, 2013 | 03:11 PM
bassplar's Avatar
Have to ask. Base timing? Not sure what you mean by that.
Old May 23, 2013 | 03:22 PM
Old May 23, 2013 | 03:23 PM
Originally Posted by Sebba
Clean your throttle body plate, and make sure you have no vac leaks as well.
Old May 29, 2013 | 07:28 AM
bassplar's Avatar
Thanks for the info. So the timing is like every other vehicle I work on, thought it was something different. Then my next, maybe stupid, question is, how does this get adjusted on the Endeavor? I am assuming it needs to be done electronically with a programmer?
I will clean the throttle body plate this weekend, and I plan on hooking up my smoke machine to hunt for leaks. Hopefully I find it.
Old Feb 15, 2014 | 11:16 PM
Galant Man's Avatar
Am going thru same replacement of gasket & spark plug tube seals tomorrow, are the seals hard to get to and pull out & what should I use (long needle nose pliers, dentist tool?) 99/Galant/2.4 Thanks
Old Feb 16, 2014 | 12:52 PM
Galant Man's Avatar
Originally Posted by bassplar
Changed out the valve cover gasket and the spark plug tube seals yesterday. So far so good. Took way too long because those valve cover gaskets were baked into the valve cover and had to be pryed/scraped out without bending the cover. That added about an hour and a half to the job. Along with finding some vacuum hoses that had been repaired with electrical tape. All in all it was a 4 hour job after two trips to the local NAPA.
I still have to clear the check engine light with my code reader, unless it goes off on its own before I see my brother again.
Thanks for the help, and I will give another update this coming weekend, but I think it is fixed.
I am going to replace valve cover gasket & spark plug seals on my 1999 2.4L -wondering how difficult it is to reach/remove seals...Thx
mitzubshi1
Apr 22, 2012 07:44 PM
adams19378
May 4, 2009 04:47 PM
760_3000GT
Aug 15, 2006 05:34 PM
m168s
Jun 27, 2005 12:47 PM
jokerkid613
Jul 2, 2003 01:42 AM
