Ac issue help
Old 02-28-2015, 03:05 PM
jmanuel's Avatar
Default Ac issue help
2005 galant es. With car on if I turn the ac switch on the engine begins to shake very aggressively.. Suspect the compressor because iwent under hood and with ac on the pulley seems to spin then stop and spin and stop or just lock completely ?? Owners manual says if there's an ac problem the ac light will flash and I'm not getting that? Any help highly appreciated thanks
Old 03-01-2015, 05:13 AM
2001Mitch3.5XS's Avatar
It sounds like ur low on Freon...
Old 03-01-2015, 11:46 AM
Akzle's Avatar
cavitating pump. As mitch said.
Or **** clutch.
Old 03-01-2015, 12:18 PM
jmanuel's Avatar
Thanks for the replies. So if its low on freon I guess there'll be a leak that needs to be fixed. Didn't know being low could cause the symptoms I'm having? Ihope thats it tho ha. And if that is the issue is there a chance my compressor could be fine?
Old 03-01-2015, 12:25 PM
jmanuel's Avatar
Also when I see the compressor pulley stop the car drops rpms and feels as if its about to shut off thanks again
Old 06-30-2015, 06:34 PM
mtcman42's Avatar
My AC seems to be getting less and less cool. I suspect that the Freon is low. Does anyone know where I can find the specs to check out the system fill and/or pressure? Thanks.
3000gt1999
11-21-2007 12:13 PM
raff1ut
02-19-2007 08:09 PM
ShowKlipse
08-21-2006 12:05 PM
redrum1er
06-23-2006 09:00 PM
koodalgo
03-28-2006 12:07 AM
Quick Reply: Ac issue help
