Ac issue help
Old Feb 28, 2015 | 03:05 PM
jmanuel's Avatar
Default Ac issue help
2005 galant es. With car on if I turn the ac switch on the engine begins to shake very aggressively.. Suspect the compressor because iwent under hood and with ac on the pulley seems to spin then stop and spin and stop or just lock completely ?? Owners manual says if there's an ac problem the ac light will flash and I'm not getting that? Any help highly appreciated thanks
Old Mar 1, 2015 | 05:13 AM
2001Mitch3.5XS's Avatar
It sounds like ur low on Freon...
Old Mar 1, 2015 | 11:46 AM
Akzle's Avatar
cavitating pump. As mitch said.
Or **** clutch.
Old Mar 1, 2015 | 12:18 PM
jmanuel's Avatar
Thanks for the replies. So if its low on freon I guess there'll be a leak that needs to be fixed. Didn't know being low could cause the symptoms I'm having? Ihope thats it tho ha. And if that is the issue is there a chance my compressor could be fine?
Old Mar 1, 2015 | 12:25 PM
jmanuel's Avatar
Also when I see the compressor pulley stop the car drops rpms and feels as if its about to shut off thanks again
Old Jun 30, 2015 | 06:34 PM
mtcman42's Avatar
My AC seems to be getting less and less cool. I suspect that the Freon is low. Does anyone know where I can find the specs to check out the system fill and/or pressure? Thanks.
3000gt1999
Nov 21, 2007 12:13 PM
raff1ut
Feb 19, 2007 08:09 PM
ShowKlipse
Aug 21, 2006 12:05 PM
redrum1er
Jun 23, 2006 09:00 PM
koodalgo
Mar 28, 2006 12:07 AM
