Cruise control help needed!
Hello everyone, so in my 2002 Montero Sport, the cruise control doesn't work. The cruise light on the dash comes on when I turn it on but it won't activate and the gas pedal won't move itself... How to fix it?
I was hoping someone who knows more about this model might be able to help you, but seems like no takers. I hope your '02 Sport has similar setup as my '01. On mine the cruise control is activated and controlled by vacuum. Check vacuum line to the cruise control actuator. Also put vacuum on the cruise actuator itself and check to see if the diaphragm inside is intact.
On the opposite side of where the cable connects to the throttle body. It is disk shaped thing looks like the one in the photo:
Google Image Result for http://img585.imageshack.us/img585/5600/1218102330f.jpg
