Cruise control help needed!
Old Mar 10, 2015 | 12:43 AM
cdvyas20's Avatar
Default Cruise control help needed!
Hello everyone, so in my 2002 Montero Sport, the cruise control doesn't work. The cruise light on the dash comes on when I turn it on but it won't activate and the gas pedal won't move itself... How to fix it?
Old Mar 18, 2015 | 04:10 PM
I was hoping someone who knows more about this model might be able to help you, but seems like no takers. I hope your '02 Sport has similar setup as my '01. On mine the cruise control is activated and controlled by vacuum. Check vacuum line to the cruise control actuator. Also put vacuum on the cruise actuator itself and check to see if the diaphragm inside is intact.
Old Mar 20, 2015 | 06:30 PM
cdvyas20's Avatar
Thanks for the reply! Where is the actuator located?
Old Mar 21, 2015 | 12:31 AM
On the opposite side of where the cable connects to the throttle body. It is disk shaped thing looks like the one in the photo:
Google Image Result for http://img585.imageshack.us/img585/5600/1218102330f.jpg
Old Mar 21, 2015 | 11:51 AM
cdvyas20's Avatar
Ok thanks! It is actually connected correctly with the black module looking thing on the very right of the vehicle! But on that black thing, there are two small pipes which I suppose are suppose to connect with each other with a small L looking hose and on mine those two are not connected! What is that for?
Pajoz
May 18, 2017 12:31 PM
ictponder
Jun 19, 2016 01:32 AM
alexlook
Dec 25, 2004 01:56 AM
robertc
Sep 11, 2004 02:09 PM
sandhillscapital
Sep 11, 2004 01:22 PM
