Engine problem
Old 04-24-2017, 09:34 PM
NMartin's Avatar
Default Engine problem
My daughter wrecked her 2003 Montero Sport 3.0 2wd, the body's totaled but the engine runs great. I bought a 2002 Montero Sport XLS 3.5 AWD with an engine that's turning out to be busted due to a failed water pump and timing belt. Can I swap the 3.0 in to the 3.5 truck? What is the compression suppose to read on the 3.5 cylinders?
Old 04-25-2017, 05:09 AM
larry4406's Avatar
Can't help you on the interchange question but on a 3.5L, the manual specifies 171 PSI standard, 127 psi minimum, with a maximum of 14 psi spread from min to max.
Old 04-25-2017, 07:02 AM
NMartin's Avatar
Thank you, I'll get started on pulling the plenum and covers tonight.
Old 04-26-2017, 04:22 PM
NMartin's Avatar
No compression reading, at all, on any of the cylinders. I'm guessing it bent every exhaust valve. Everything looks ok, but obviously it's not.
M
12-15-2005 06:31 PM
winglesseclipse
07-06-2005 08:55 PM
Cat77
05-03-2005 03:24 PM
ang099
06-28-2004 12:15 AM
Quick Reply: Engine problem
