Bluetooth module activation
Hi, Can I ask you how did you do it? Becouse I´m trying to install it on my Lancer 08, but I have a few doubts about the connection. I saw that the steering column is pre-wired for something, but I don´t know if that connector is for the buttons of the hands-free module or the paddle shift.
Thanks!
Thanks!
As I understand it, it is just a toggle to let the ecu know it is there - as per these mut-3 instructions:
http://ww2.justanswer.com/uploads/SU...ander_pg11.pdf
From 2008 onwards that was pre-set to on, but before then for stability reasons had to be turned off if the btm was not present. So I read somewhere.
I have the opposite problem in that my module is installed, and I'm guessing has never been activated. I'm hoping getting it activated will be enough to make it work.
Help!!!
Thanks!
Thanks!
TXS, Paula
P.S. also a 2008 Lancer 😊
kevsb
10-15-2020 10:22 PM
