Bluetooth problem
Old Nov 19, 2018 | 08:22 AM
bouncer555's Avatar
Default Bluetooth problem
If I wiggle the wires connecting my Bluetooth module it will work for a short while, sometimes a few hours sometimes a few days , I have been told that if the module was faulty it would not work at all, I don't want to replace the module and then find the problem persists.
Any Ideas ?
Old Nov 19, 2018 | 09:15 AM
AWCAWD's Avatar
Any Ideas ?
Troubleshooting must always involve some experimentation. I would get a multimeter first and check the wires for continuity and the connections for corrosion and any deposits that may spoil your electrical connection.Unless your Bluetooth module is bad you should be able to fix it either by rewiring or cleaning the connections. Should you need a Bluetooth module I would start in a junk yard. You may pull one from a 2010+ Lancer, Ralliart, Evo X, Outlander or Outlander Sport/RVR/ASX for few bucks.
mandi_m_m
Mar 9, 2021 08:08 AM
Peter Banks
Aug 17, 2011 03:47 PM
TONETHEBONE
Feb 4, 2010 03:08 PM
saro54
Jan 20, 2010 06:12 PM
nieves74
Oct 5, 2009 03:02 PM
