2002 Montero Power Antenna
Old Jul 6, 2008 | 12:11 AM
amatc20's Avatar
Default 2002 Montero Power Antenna
I just found out while I was trying to replace the antenna mast on my Montero that the plastic part on the old antenna is broken off inside the motor. I cannot find a way to get to the motor, is this a major repair? Do you have to take off the fender to repair the motor? Help!!
Old Jul 6, 2008 | 01:26 PM
Default RE: 2002 Montero Power Antenna
you will need to remove the motor and disassemble it.
its quite a bit of work on a montero.
Old Jul 19, 2008 | 07:19 AM
fuki's Avatar
Hi, I have question about power antenna.How do you remove this ring nut???I need change my antenna must, but I do not know how to remove the ring nut.Thanks for help.
Old Jan 20, 2010 | 02:43 AM
mrmisha19's Avatar
When I had to replace the antenna mast I was fortunate that the plastic part wasn't stuck in the motor. I simply used a rag and an adjustable wrench, the rag protects the chrome finish.
Old Oct 8, 2010 | 04:02 PM
wibq's Avatar
Default how to get at power antenna
How do you get to the power antenna on a 2003 Montero LTD?
How much work and time is involved?
Old Oct 9, 2010 | 04:53 AM
redturboeclipse's Avatar
tedious, and its the same for 01-06 in the USA, montero (not sport) ltd or xls, of course the xls may not have power.
To get to it requires possible removing the wheel, depending on how skilled and how well you can snake around down there, then removing fender lining.
then a few bolts to loosen the power antenna from the mount..
harder part is removing entire thing (which means the wiring), have to snake it from the interior where its hooked to the stereo panel, which means removing interior panels.
so yea its straight forward but tedious, of course some parts are easier depending on the excessiveness of the job
Old May 2, 2012 | 12:14 PM
RERM's Avatar
How do I know if the cable is broken inside the motor???
Greg Yancey
Apr 26, 2013 08:55 PM
Greg Yancey
Oct 23, 2012 10:59 AM
captchuck
Jul 12, 2010 08:25 PM
redturboeclipse
Oct 26, 2009 10:41 PM
tulsa44
Oct 26, 2009 10:27 PM
