2003 Montero Limited Power Antenna
Old Jul 12, 2010 | 04:10 PM
captchuck's Avatar
Default 2003 Montero Limited Power Antenna
OK, I just purchased used a 2003 Montero Limited and 2 things i need to address are:
1) Power antenna retracted and extended just fine at purchase, but now motor runs to no avail.....dealer tells me i need a rod at $45.....is it going to be a hassle to change out?
2) rear tire is missing the center hub cover....have part and spring ordered to replace....any keys I should no about on this or is it common sense? I assume it cant be that difficult?
Thanks for any insight on these two repairs.
Capt. Chuck
North Carolina
Old Jul 12, 2010 | 08:25 PM
MitsMaster's Avatar
If the cable that pulls and pushes the antenna is broken you will have to pull the motor out and open the case to remove the broken piece. If you are not good with tools, I wouldnt try it. On the wheel cap, you just have to remove the tire and put the retainer on from the back side. If it is a Montero Sport, there is two different retainers, one for the front and one for the rear. one silver colored and one gold colored. Right on the tip of the retainer is a R or F hard to see.
Greg Yancey
Apr 26, 2013 08:55 PM
RERM
Nov 21, 2012 03:02 PM
amatc20
May 2, 2012 12:14 PM
redturboeclipse
Oct 26, 2009 10:41 PM
tulsa44
Oct 26, 2009 10:27 PM
