Can a permanent flexible antenna be fitted to a 2003 Montero Limited?
Old May 2, 2012 | 12:34 PM
RERM's Avatar
Default Can a permanent flexible antenna be fitted to a 2003 Montero Limited?
My power antenna broke, the motor works, but the cable came off...I was wondering wether to fix it or swap it for a permanent (non power) aftermarket replacement...
Old May 8, 2012 | 01:35 AM
redturboeclipse's Avatar
yes you can, but you need to pull the entire assembly out.
very tedious. but straight forward. i hacked it so the power antenna just sits mid point and no longer "turns on" because the cable broke too and could not just repalce the mast. the entire assembly ahd to be replaced.
but the signal is weaker half up. if i wasnt lazy and i cared more about the car i would prob repalce it with a non power one.
it would benefit me too because i have HD radio and the works!
Old May 8, 2012 | 05:42 PM
Mr. Z.'s Avatar
The entire assembly is a very costly replacement.
I'm waiting for a new mast that I ordered to replace one that snapped off. (Thankfully, the motor works fine.)
The plan is: Splice into the power that feeds the antenna assembly from the stereo, and run it through a switch (mounted in the cabin). This way I can have the antenna up when desired (on-road driving), or down (off-road driving).
Old May 8, 2012 | 07:21 PM
mxmikie's Avatar
i bought a complete elec ant for my montero on ebay for $40.00
Old May 8, 2012 | 07:53 PM
Mr. Z.'s Avatar
Hopefully it'll last as long as the OEM unit...if it dies an early death, you can still buy a couple more and not even spend the cost of an OEM unit.
Old Nov 21, 2012 | 03:02 PM
RERM's Avatar
Well, I bought an OEM mast on EBAY for $40, but now, I can't seem to get the left over antenna out???
The top of the antenna came off with all the cable, but I still have the bottom 3 metal sections in place (about half the antenna) I try yanking the thing out, but it just won't budge.
BTW, I already took the top nut off, the dammed metal just wont come OFF!!!
navidbe
Nov 20, 2013 09:17 PM
captchuck
Jul 12, 2010 08:25 PM
mirag3
May 4, 2006 07:54 PM
Joel_CA
Apr 3, 2006 10:25 AM
PaintMunky468
Dec 15, 2004 09:47 PM
