Old Apr 21, 2011 | 10:42 PM
  #1051
rcorona8's Avatar
Originally Posted by rcorona8
Is there a new patch for this (above Version) yet? is someone working on this? i would really love to watch dvds on the go. thanks.
P.S i just bought my 2011 outlander xls and love it. .....
Bump!
any pointers???
Old Apr 23, 2011 | 03:31 AM
  #1052
WiValdiBB's Avatar
You have cut/block (ground) GPS signal. There is no patched software
Old Apr 24, 2011 | 12:24 AM
  #1053
rcorona8's Avatar
can you give me a 5 second lesson on how to cut/block gps signal??maybe a DIY thread? what is the down side of such procedure above? thank you.
Old Apr 24, 2011 | 11:39 AM
  #1054
WiValdiBB's Avatar
You have to install relay on GPS signal cable and ON/OFF switch.
AUX and DVD will work then when You drive but navigation part of MMCS doesn't show the actual position.
If You need navigation then shortly after switch ON GPS signal it will works again. You have to look to internet DIY has been published somewhere too, I'm sure, I remeber I found simply description about that
Old Apr 25, 2011 | 03:21 PM
  #1055
Darksun280's Avatar
Is there a patch for this one
BLD-NR 261UM 1.09
00.41.02
After reading this thread it looks like no.
Old Apr 26, 2011 | 03:14 AM
  #1056
WiValdiBB's Avatar
BLD-NR 261UM 1.09
00.41.02
In my knowledge there is no patch. The latest for UM is: 30.99
Download links are in my post, look at: http://peb.pl/sprzet-do-nawigacji/10...itsubishi.html
It's Polish but download links are usefully too
Old Apr 27, 2011 | 11:17 PM
  #1057
rcorona8's Avatar
to save my life i can't find any good clear thread on the gps on/off switch. They are all old and they talk about grounding the e-brake or putting a switch somewhere else (green cable) instead of the gps. any help would be appreciated.
Old May 15, 2011 | 07:48 AM
  #1058
nippon's Avatar
DAMN IT ! LOL just read through the thread . took 2-3 hours . was hoping the patch for the aux would be in hopes of an end . sadly not . great work on it so far hats off to the lot of you . and thanks . the kids are enjoying the dvd in motion . keep up the good work . had to register just to reply to this thread.
Old May 20, 2011 | 06:16 AM
  #1059
siddharta_74's Avatar
Hi to everyone.
Is there a hope to apply a patch to my MMCS
BLD-NR-261EM-PUG 1.10 application version 50.04?
I tried to unlock HD and manually replace LOADING.KWI
with a patched one,cold boot the system but I get
an error while loading.The CD method doesn't work either
(using version 50.11).
Thanks in advance
Old May 25, 2011 | 12:27 PM
  #1060
WiValdiBB's Avatar
Originally Posted by siddharta_74
Hi to everyone.
Thanks in advance
In my knowledge there is NOT patched software for PUG, CTR and they are some different then Mitsubishi loading.kwi file
